We need to first make sure your getting power to the starter. There is a large wire and a smaller one on the back of the solenoid. You'll need a helper. Using a test light connected to batt (-), probe the smaller wire and have someone try to start it. If the test light lights up, you're getting signal from the ingnition switch. Check the big wire with the same test light. There should be power there all the time. Check all the battery connections and make sure they're clean and in good shape.
If all that doesn't test out ok, the security system may be taking over. Make sure you have the correct key. The security system is pretty tricky and smart. See what happens and repost and I'll keep trying to help.
SPONSORED LINKS
Saturday, December 6th, 2008 AT 10:59 AM
