My car for some reason want start. I have checked the battery, the cables, and checked the wiring to make sure that there was nothing loose. Everytime that I try to start the car you can hear a click at this fuse. The codes that I saw on the fuse is GM ABS V1 and some other information that is on the plug is OMRON R135010 Doo 77365. I am just wondering if the ignition switch has a fuse and if so do you think that it needs to be replace. Or do you just think that the starter has gone cause I couldn't find it anywhere. Thanks for your time.
Need a fix!
SPONSORED LINKS
Saturday, May 29th, 2010 AT 1:22 AM
