1991 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
Car will turn over, but it will not start, even after the car has been on jumper cables for about an hour
Monday, January 18th, 2010 AT 1:20 PM
JDL
MECHANIC
Welcome to the forum, If it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Also, check for trouble codes.
