1990 Oldsmobile Cutlass won't start now
TW4JW
  • 1990 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 130,000 MILES
My husband (former mechanic) had to replace the o-ring on his oil pump. It started just fine afterward-we let it run for about 5 miutes, shut it down, and now it won't restart. There's fuel getting to the engine, plenty of oil, no kinks in lines, sensors are hooked back up and none of the fuses seem to be blown. Any ideas?
Wednesday, January 21st, 2009 AT 2:10 PM
JDL
  • 16,098 POSTS
You might check for codes, see if that points in any direction? Can you do some of the basic tests? Check for spark at the plugs and injector pulse, with the engine cranking.
I guess your saying it cranks good?
Wednesday, January 21st, 2009 AT 2:16 PM
