Engine not starting
CLAYTON55
  • 1990 OLDSMOBILE CUTLASS
Engine Mechanical problem
1990 Oldsmobile Cutlass 4 cyl Front Wheel Drive Automatic
ran fine before I replaced the starter and now it turns over but nothing there is fuel pressure and ive replaced the coil packs and tower
Monday, July 5th, 2010 AT 3:55 PM
  • 109,794 POSTS
Did you check for spark? Will it start with starting fluid?
Monday, July 5th, 2010 AT 8:55 PM
DELLA MARIE BENNETT
Check that the engine wire to the starter is connected. I can't remember the vehicle but it had a blue wire that went on the thread as well. I meant a small blue or purple wire.
Wednesday, July 19th, 2017 AT 6:03 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,814 POSTS
Thanks for the information and you are right it sounds like a wire was left off of the starter and now there is no power to the ignition and other systems.
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Thursday, July 20th, 2017 AT 11:09 AM
