1990 Oldsmobile Cutlass please help!!!
1990 OLDSMOBILE CUTLASS
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARIELLC
my oldsmobile was driving fine this morning. i parked it and returned a few hours later. it wouldnt start. it sounds like my battery is dying at a very slow cranking but when checked with a voltage meter it was fine. at a glance it looks like my belt is jammed and trying to crank but cant/wont. when trying to start the vehicle, it gives off the smell of burnt rubber/plastic in that area but doesnt look as if the belt is snapped or melted off. what could be wrong?
Jun 21, 2010 at 7:26 AM
  • 110,244 POSTS
Is the belt jamed in the pullies? Also, if it isn't, I need you to remove the battery, take it to a parts store, and have them load test it. If it is good, the belt is good, remove the starter and have it bench tested at a parts store. Most will do it for free.
Jul 1, 2010 at 6:40 AM
YOTATECH
  • 5 POSTS
Could be a burned up alternator or (Generator) from a belt being too loose or tight. Maybe check the generator out. If it looks burnt that maybe your problem.
Aug 5, 2010 at 6:14 AM
