Welcome to the site, you need to use a gage to check for proper fuel pressure. Yes, you need to check for injector pulse. Use a noid lite on the injector plug, there should be a pulse, engine cranking. If no pulse, look for an rpm signal. I don't suspect the crank sensor. Possibilities, ignition module--wiring circuit to or from the computer.
SPONSORED LINKS
Monday, September 28th, 2009 AT 12:59 PM
