1989 Oldsmobile Cutlass
LUIS_COLON22
  • 1989 OLDSMOBILE CUTLASS
  • 6 CYL
  • 114,675 MILES
Car crank real good and wont start has new battery new alternator
Saturday, February 28th, 2009 AT 10:01 AM
JDL
  • 16,098 POSTS
Hello, are there any codes? Your obd1, you should be able to check yourself.
https://www.2carpros.com/forum/automotive_pictures/170934_aldl_9.jpg
If your data link connector looks like the above, use a jumper between the A & B terminals. Turn the key till the dash lites come on, no further. The mil starts flashing, you count the flashes to get the codes.
You could also do some basic tests, have a helper crank it while you check for spark at the plugs and injector pulse.
Saturday, February 28th, 2009 AT 10:51 AM
