I have a 1989 Oldsmobile Cutlass Ciera with the 2.5. It will start then idle for a second and shut off. I've checked all the usual stuff spark plugs and wires replaced fuel pump and filter checked fuel lines checked fuses and relays checked all grounds and wire connections. The check engine light does not come on and if there are codes I have no way of reading them. It started when I went and got fuel left the gas station parked the car and shut it off since then it has not started.
SPONSORED LINKS
Friday, September 10th, 2010 AT 5:01 PM
