Welcome to the forum, have a helper crank it, while you check for spark at the plugs. You can pull a plug boot, stick known good plug in the boot, let metal part of plug touch metal part of engine, watch for spark at the tip of plug. The autostore sells a spark tester. Also, use a gage and check fuel pressure.
SPONSORED LINKS
Thursday, November 5th, 2009 AT 9:09 AM
