1993 Oldsmobile Ciera engine
1993 OLDSMOBILE CIERA
90,000 MILES • 6 CYL • FWD • AUTOMATIC
MINTY442
i hit the gas in gear or in park the engine bogs and almost backfires. car has no torque even in reverse. ipunch it in gear it goes no where if u punch it in gear ir comes out of gear and revs.
Apr 14, 2010 at 1:58 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 14, 2010 at 8:08 PM
