1988 Oldsmobile Ciera lost power
ZACHLAKE
  • 1988 OLDSMOBILE CIERA
  • 6 CYL
  • FWD
  • 135,000 MILES
Hi, two months ago I had a loss of power driving down the road. I changed the catalytic converter, fuel filter, spark plugs, wires, and finally found out my problem was my center coil pack.
Yesterday, I had the same sudden loss of power, so I went and picked up two more coil packs so that I'd have a full set of three. I replaced these and still have the loss of power, I checked the middle one I had originally changed and it was ok too. I checked all the plugs and they looked fine. Do you have any suggestions on what I should do next? Thanks in advance!
Thursday, June 18th, 2009 AT 3:08 PM
JDL
  • 16,098 POSTS
Hello, any codes? It would be nice if you could rule out something. You need a fuel pressure gage to rule that out. Is the problem intermittent, does it idle ok?
Thursday, June 18th, 2009 AT 3:46 PM
ZACHLAKE
Yes it idles ok, and it has fuel pressure. I haven't had it hooked up to a computer yet?
Thursday, June 18th, 2009 AT 4:13 PM
