The car won't start
It has fuel and spark
The crank sensor has been replaced
After putting a pressure gauge at it, it read 48 psi at the rail.
Someone said it may be a computer problem can you elaborate?
Sunday, May 10th, 2009 AT 4:29 PM
MECHANIC
Do you have injection pulses from the injectors?
SPONSORED LINKS
Sunday, May 10th, 2009 AT 4:46 PM
ELZZUP
MEMBER
Not sure, how do you check?
Sunday, May 10th, 2009 AT 4:48 PM
MECHANIC
Crank engine over and listen if the injector/s are clicking
