It starts fine the 1st time but, will only start again after you turn the engine off and allow it to sit for about 20-30 mins.
If you try to restart it before it sits for 20-30 mins, it will crank but not start.
My mechanic replaced the cranks sensor, but the problem persists.
My mechanic also ruled out the fuel pump as the source of the problem.
The car has a 3.3L V6 with about 90K miles on it and the spark plugs only have about 3000 miles on them.
Could the problem be related to the engine coolant temperature sensor or the electronic control module?
SPONSORED LINKS
Wednesday, June 2nd, 2010 AT 10:21 AM
