HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Ciera
Engine
Symptoms
Not Running
SPONSORED LINKS
1989 Oldsmobile Ciera car not starting
WILLIE JOHNSON
MEMBER
1989 OLDSMOBILE CIERA
Engine Mechanical problem
1989 Oldsmobile Ciera 6 cyl
car cut off while I driving checked fuel pump that is ok getting spark what can it be that the car wont start
Tuesday, June 16th, 2009 AT 7:59 AM
JDL
MECHANIC
Hello, are there any codes? With the engine cranking, is there an injector pulse? Use a gage check fuel pressure.
SPONSORED LINKS
Tuesday, June 16th, 2009 AT 10:53 AM
WILLIE JOHNSON
MEMBER
There are no codes and there is injector pulse
Friday, June 19th, 2009 AT 12:16 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1989 Oldsmobile Ciera Starting Problem With My 1989...
I Am Having An Intermittent Problem With My 1989 Olds Cutlass Cierra. It Starts Fine The 1st Time But, Will Only Start Again After You...
Asked by
erniemary
1 ANSWER
1989
OLDSMOBILE CIERA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1987 Oldsmobile Ciera Engine Turns Over, But Won't...
My Son Was Driving This Car When The Problems Started. The Car Would Just Stall Out And The First Few Times, It Started At A Later Time....
Asked by
cfronk
1 ANSWER
1987
OLDSMOBILE CIERA
1990 Oldsmobile Ciera Engine Turns Over But Won't...
Electrical Problem 1990 Oldsmobile Ciera Front Wheel Drive Automatic The Injectors Won't Let Fuel Through, I Disconnected The...
Asked by
Brian 59v
1990
OLDSMOBILE CIERA
95 Ciera Will Not Start After Sitting For A Couple...
I Have A Orange Spark When I Check The Plugs. The Fuel Pump Only Comes On When I Bypass The Relay. But The Car Still Will Not Start Even...
Asked by
allisswell
1995
OLDSMOBILE CIERA
1988 Oldsmobile Ciera Engine Will Not Start When Warm
This Engin Srarts Good When It Is Cold But After It Has Been Run Long Enough To Heat Up Good Like After It Has Been Run 5 Miles And Shut...
Asked by
mhock1928
1988
OLDSMOBILE CIERA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
