2003 Oldsmobile Bravada
2003 OLDSMOBILE BRAVADA
102,000 MILES • 6 CYL • 4WD • AUTOMATIC
Z BARB GO
I have 4WD. Dealership service department has told me that the back wheels are engaging, but the front wheels are not. I have been told that the problem for this cannot be diagnosed until they take apart the ?? differential?
What would cause this problem with the front wheels not engaging? Could it be a problem with the differential? transfer case? driveshaft?
I understand that they can detect this problem by putting the car up, putting it into gear and looking at the wheels spinning.
I have 102,000 miles on the car. It has had every scheduled service done (on time) and oil changed every 3,000 miles. I had the front differential service done in Nov., 2009.
Feb 24, 2010 at 9:48 AM
HMAC300
  • 48,601 POSTS
because y ou have all wheel drive on your truck, they have to disassemble the transfer case to see why the front wheel doesn't work. It can be clutches or a broken chain or something similar to that.
Mar 2, 2010 at 10:02 AM
