All wheel drive not working?
TODD1955
  • 1997 OLDSMOBILE BRAVADA
  • 6 CYL
  • AWD
  • 117,000 MILES
I got stuck in snow and was told that only my rear wheels spun, when in returned home, I jacked up rear of suv to trick computer into thinking rear wheels were slipping and front wheels did not work.
Friday, December 19th, 2008 AT 2:26 PM
  • 109,874 POSTS
Hi:
Is your truck AWD or do you put it in 4wd with a switch or lever?
Monday, December 22nd, 2008 AT 3:30 PM
TODD1955
  • 7 POSTS
It is a constant awd, I have no switch, oldsmobile calls it "smart trac"
Tuesday, December 23rd, 2008 AT 9:09 AM
  • 109,874 POSTS
Todd,
The smart track, like you said, should be working all the time. Unless someone stole the front frive shaft. I will repost your question with the other techs because I'm not as good with the smart track system. I'm sure one will contact you soon.
Tuesday, December 23rd, 2008 AT 10:46 AM
TODD1955
  • 7 POSTS
I got under the bravada and verified that there was a drive shaft going to front diff. That was my first thought that the driveshaft was removed to get better gas mileage. Thank you for your time Joe and I will let you know what comes of it so you can use the info for future customers.
Tuesday, December 23rd, 2008 AT 11:28 AM
TODD1955
  • 7 POSTS
Jacked up rearend off bravada to make it think that rear wheels were slipping, driveshaft was turning to the front axle, but front wheels did not try to turn, that removed transfer case out of the picture I think, I hope that helps you diagnose problem.
Saturday, December 27th, 2008 AT 6:03 PM
AD142314
  • 6 POSTS
Your front differential has a internal problem if the tranfer case is not acting up.I had to rebuild my front diffiential on my 97 oldsmobile bravada.
Saturday, November 7th, 2009 AT 12:32 AM
