1998 Oldsmobile Aurora Changing Oil Pan Gasket
1998 OLDSMOBILE AURORA
GC3MAX2
Engine Mechanical problem
1998 Oldsmobile Aurora V8 Automatic 111000 miles
What are the steps/How do I change the oil drain pan gasket on the 98 Olds Aurora?
Mar 25, 2010 at 3:13 AM
  • 110,240 POSTS
Basically, it just unbolts from the engine block. Make sure there is enough clearance for it to come off. You may have to securely raise the engine slightly to remove the pan.
Apr 9, 2010 at 12:19 AM
