1995 Oldsmobile Aurora 1995 olds Aurora (off and on) starti
DBLUVETTE
  • 1995 OLDSMOBILE AURORA
  • V8
  • FWD
  • 146,000 MILES
1995 olds aurora sometimes wont start with key
but will always start with aftermarket remote start (viper system)
then put key in car will die.
when car is working properly. Remote start insert key everything ok
have had ignition cylinder replaced and new key
have disconnected hood safety wire to remote start
when starting with key. Could go 2 weeks no prob.
then turn key everything in car comes on but no starter engage. No clicks. Nothing
get out of car lock it up and hit the remote start. Car starts every time.
when car dosent start. Sometimes the security code. Sometimes the key code. Sometimes no code
CAR ALSO TURNS OFF WHILE DRIVING. NOT GOOD
THIS IS MY 17 YEAR OLD DAUGHTERS CAR. SHE IS NOW WITHOUT TRANSPORTATION I WONT ALLOE ANYONE TO DRIVE THIS VEHICLE WITH THIS PROBLEM! VERY UNSAFE!
Saturday, January 31st, 2009 AT 10:41 AM
JNOVACK
  • 723 POSTS
Try this and let me know what happens
To override the starter kill, turn
the ignition on and press the
Valet button within 10 seconds.
The status LED will stop flashing
and the vehicle should start. If it does not start,
you may have waited too long; turn the ignition off and repeat the
process.
The Valet button is on the Interface Module under the dashboard most likey on the driver side and if this doesn't help then you can disconect the whole system I am waiting on Viper to send me the info on how to remove
I also recieved this from viper
Where's the Valet switch? Locked away in the glove box! Open the vehicle's door and get in and out of Valet by pressing 1-2-1 on your remote. Remote Valet turns security off but leaves convenience on. You can turn off the system for servicing or valet parking directly from the remote control. Convenience by remote control: No more reaching for a switch installed in the vehicle.
Saturday, January 31st, 2009 AT 6:36 PM
DBLUVETTE
Tried the valet on off, and confirmed correct operation
left it off started car about 10 times local drives to store etc. Then same thing. Tried 2 xs. Nothing then started on the 3rd try
do recall this problem 8-07 when we first got the car
it did it for a few times in the driveway and not again for about 8-10 mo later. This was before the viper system
since then I have replaced: fuel pump
fuel pressure regulator
ignition cylinder and key
had car back to that guy 3xs
diagnostic at cadallac dealership
they said they couldnt be sure unless viper was completely removed from vehicle
also all electrical in this car works. Lights fan stereo wipers. Etc. Accept air cond
hope this helps
waiting to haer back
thanks
art dixon dbluvette@comcast. Net
Sunday, February 1st, 2009 AT 10:13 PM
JNOVACK
  • 723 POSTS
What you need to do now is with fuel pressure tester run car in drive till it stops keeping an eye on pressure let me know if you loose pressure
41-47 PSI(Pounds per Square Inch)
Note:
Position the ignition switch and the A/C system in the
off position. Install a fuel pressure gauge to the
vehicles fuel pressure valve.
Confirm that no leaks are present, and with the key
on, engine off verify the PSI reading on the gauge.
And then start car and let run till it stops I beleive you said it takes about 10 min. You could have a bad fuel pump or filter
Monday, February 2nd, 2009 AT 9:02 AM
DBLUVETTE
Are you sure this fuel pump reply is to me?
Fuel pump is new and so is regulator.
Im having off and on electrical prob
please confirm, its 15 miles to place where pump and regulator were done
thanks
art dixon
Monday, February 2nd, 2009 AT 9:48 AM
JNOVACK
  • 723 POSTS
Ok know inspect these items
Inspect EGR Valve Clogged, dirty or improperly functioning or defective egr valve.
Inspect MAP Sensor Improperly connected or faulty m.A.P. Sensor.
Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor.
Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor.
Inspect Fuel Filter Clogged or dirty fuel filter
Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system.
Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
Inspect Spark Plug Fouled, damaged or broken spark plug(s).
Inspect PCV Valve Plugged or damaged pcv valve.
Monday, February 2nd, 2009 AT 12:56 PM
DBLUVETTE
GOT YOUR LIST OF ITEMS TO CHK.
CAR IS AT DEALERSHIP AGAIN.
THEYRE STILL WHINING ABOUT VIPER SYSTEM.
THEIR TECH SAID HE WAS LEANING TOWARD.
THE (IGNITION MODULE).$250.00 AT
LOCAL AUTO PARTS STORE.
WHAT DO YOU THINK?
ALSO.
@ ON YOUR LIST. WHAT IS (MAP SENSOR)?
@ WHAT DOES IT DO?
@ DOES VEHICLE READ IGN MOD AND OR MAP SEN
WHILE ENGINE RUNNING?
@COULD THESE ELECTRICAL PARTS FUNCTION AND MALFUNCTION. WORK AND NOT WORK BEFORE
THEY GO BAD?
@ COULD YOU CONTACT VIPER AND ASK ABOUT POSSIBLE INTERFERANCE ON THE NORTHSTAR SYSTEM?
@ THIS VEHICLE IS 14 YEARS OLD YOU WOULD THINK DEALERSHIP NETWORK WOULD HAVE SEEN THIS PROBLEM 100'S OF TIMES.
@WHERE EVER WE END UP THIS WILL BE VALUABLE TO YOUR DATA BASE. IF WE FIGURE IT OUT ON OUR END I WILL GLADLY NOTIFY YOU WITH THE INFO!
@@@@@@THANKS@@@@@@
ART DIXON dbluvette@comcast. Net
Wednesday, February 4th, 2009 AT 4:29 PM
JNOVACK
  • 723 POSTS
A manifold absolute pressure sensor (MAP) is one of the sensors used in an internal combustion engine's electronic control system. And yes the ignition control modual can and will go out or even heat up and intermitantly go out so can all the sensors on engines you have camshaft position sensor crankshaft position sensor ignition control modual ect. That all control the engine and its functions
Wednesday, February 4th, 2009 AT 4:40 PM
