Symptoms: The car seems to stall the most when you stop giving it gas, while driving. It doesn't seem to happen until the car is warmed up. It starts great when it is cold and before it gets warmed up, but is very hard to start once it has stalled. The battery voltage looks good while driving (15.3 V) and while cranking 13.4V. It doesn't sputter or shake when it dies, it just simply dies very suddenly like you turned off the ignition. The lights stay on and don't flash when the car stalls. It is not giving any error codes when it stalls. I tried using a secondary key thinking the resistor might be bad but that didn't make a difference.
Is there a way to test the ignition, PCM, or other system that might be failing here?
SPONSORED LINKS
Monday, February 22nd, 2010 AT 10:16 PM
