1995 Oldsmobile Aurora
1995 OLDSMOBILE AURORA
WILL63067
1995 Oldsmobile Aurora V8
where is the iac located and where to find it
Feb 7, 2010 at 6:35 AM
ERNEST CLARK
  • 1,730 POSTS
It's located right next to the throttle body.
Your air filter is located inside a black plastic box. A plastic tube called a "Air intake plenum" runs from that box to your engine. Your throttle body is inside of this tube right where it meats with your engine. On the outside of the throttle is a black plastic sensor which screw into the side of the throttle body.
Feb 8, 2010 at 10:55 PM
