2003 Oldsmobile Alero Charging problem
2003 OLDSMOBILE ALERO
176,000 MILES • 6 CYL • FWD • AUTOMATIC
DANIK2212
Hi, first of all thank you for helping me. Here's the problem, the battery's voltage drops while the cars is running. I'm using a brand new battery (in fact I tried 3 different batteries) and I just bought an alternator from a scrap yard. The guy there tested the alternator and told me it was charging at 14,87 volts... I verified all the connections and the pulley and everything seems to be ok... All the electrical components in the car (radio, windows, door locks, lights, ect.) are working. I checked every fuses in the three fuse boxes and none is broken.
Here are some things to consider:
- The car remained park for the winter outside but got started every here and then
- Because the car wasn't starting (battery was dead) I boosted my car, but I accidentally plug the wires backward on my old battery (red on black and black on red) and white smoke came out of my hood). I then changed the alternator and battery after...
My car:
2003 alero gl2
v6 3,4L
stock tranny
stock everything
Apr 18, 2010 at 3:29 PM
LEGITIMATE007
  • 5,121 POSTS
did this new alternator and battery come after you crossed the wires?
Apr 21, 2010 at 2:30 AM
DANIK2212
yes they did, I did nothing wrong with the new alternator and battery
Apr 23, 2010 at 2:50 PM
LEGITIMATE007
  • 5,121 POSTS
Yes this is obviously an electrical problem and I'm suspecting the ecm. In my experience crossed wires will short out the ecm .we will need to have it tested at a repair shop
Apr 23, 2010 at 11:27 PM
