Tell The Difference Between A Battery And An Alternator
2003 OLDSMOBILE ALERO
138,000 MILES • 4 CYL • FWD • AUTOMATIC
MOLLY GRUE
Over the past three days, my car started to be sluggish when starting, but it did start and worked through the day- yesterday it was driven 10 miles to work, sat for 7 hours and started to be driven back. This morning the engine slowly tried to turn over, but couldn't make it. Yesterday and today the clock showed 12 when the key was turned, so obviously there is a battery issue, but I don't know if I just need to replace the battery or deal with the alternator. No machine gun noises when ignition is engaged, just the battery not turning over the engine. Not quite sure how to handle the problem this morning; would like to get to work!!
Aug 19, 2014 at 6:23 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
check battery for condition including load test. if you jump it and get it running autoparts can test it and charging system they do for free as well as tire stores
Aug 19, 2014 at 6:43 AM
MOLLY GRUE
Thank you very much! AAA will jump me and get me to Auto Zone then. Appreciate the help. :)
Aug 19, 2014 at 6:53 AM
