2000 Oldsmobile Alero troubleshooting
VERITASG
  • 2000 OLDSMOBILE ALERO
Engine Performance problem
2000 Oldsmobile Alero 4 cyl Two Wheel Drive 24,000 miles
My car will not start.Feul leakage through the fuel regulator tried replacing did not fix problem what your suggestion?
http://www.2carpros.com/forum/automotive_pictures/487527_kitty_cat_001_1.jpg
Sunday, February 21st, 2010 AT 8:24 PM
ERNEST CLARK
  • 1,730 POSTS
The first thing to check is spark, then fuel, computer and sensors, and finally compression.
If one step checks out, move to the next step. If for example, there's no spark, then you must find out why. Begin with the plugs, wires, coils, computer, etc. Check everything that allows your ignition system to produce a spark, including the crank/cam sensors.
Don't just replace parts. Test them until you find something faulty.
Sunday, February 28th, 2010 AT 7:13 AM
