Engine Mechanical problem
2000 Oldsmobile Alero 6 cyl Two Wheel Drive Automatic
Starter motor sounds like its spinning but not engaging the motor.
Saturday, July 18th, 2009 AT 8:53 PM
JDL
MECHANIC
Hello, is the starter loose? Can you tell if the starter is kicking out the pinion gear, key in the crank position? There is probably a dust cover for the flex-plate, underneath, I'm not sure if you can see the pinion gear from there?
