Replaced fuel pump, just turns over, but won't start.
Wednesday, August 25th, 2010 AT 9:06 AM
MECHANIC
Check the fuel pressure if it's within specs. Do you have spark?
SPONSORED LINKS
Wednesday, August 25th, 2010 AT 10:35 AM
JDL
MECHANIC
With the engine cranking, do you have spark at the plugs? Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. Use a noid lite and check for injector pulse. Are there any applicable trouble codes?
