HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
88
Engine
Symptoms
Not Running
SPONSORED LINKS
1992 Oldsmobile 88 starting
SILVERWOLF48
MEMBER
1992 OLDSMOBILE 88
1992 Oldsmobile 88
this car has a chip in the key. It will not start by key but you can crank it monentary by jumping the start wire at starter
Saturday, May 29th, 2010 AT 4:06 PM
MECHANIC
The security system will shut down the fuel system. If it starts when you jump the starter, the security system isn't the problem.
Let me know if that is what is happening. Also, let me know if the security light is on or flashing all the time.
SPONSORED LINKS
Friday, August 13th, 2010 AT 9:51 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1992 Oldsmobile 88 "new" Car Won't Start
Bought A '92 88 Royale From Family. Test Drove On 2 Different Occasions, Then Bought And Drove Home 50 Miles With No Problems. Next Day...
Asked by
scheu001
1992
OLDSMOBILE 88
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Oldsmobile 88 Intermintent Starting Problem
Electrical Problem 1992 Oldsmobile 88 6 Cyl 200000 Miles Hi Guys! I Just Bought This Car, Did Not Know It Had This Problem, Just...
Asked by
classic
1992
OLDSMOBILE 88
No Spark And Will Not Start
My Car Told Me To Replace The Throttle Position Sensor And The Camshaft Sensor Because They Were Bad. I Did, And The Codes Went Away, But...
Asked by
huskyman
1992
OLDSMOBILE 88
Car Cranks Fine, But Will Not Start
My 1992 Olds Eighty-eight Was Acting Funny For A Week Or So. Whenever It Was Idling, It Would Not Idle At A Constant Level. It Would Be...
Asked by
pgibson6
1 ANSWER
1992
OLDSMOBILE 88
1992 Oldsmobile 88 Won't Start
Replaced Fuel Pump, Just Turns Over, But Won't Start.
Asked by
solosologuy
1992
OLDSMOBILE 88
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
