Engine burning too much oil
67,873 MILES • 4.6L • V8 • AUTOMATIC
ARCH MIKE
I have a problem with my car burning too much oil. I just recently gave it an oil change , changed all the coils and put new spark plugs. I passed a smog and it runs pretty decent. But it still burning too much oil. I did this tune up about a week and a half ago if that. And already i had to add another 2 quarts. What could be the reason? Please help.
Apr 28, 2020 at 7:24 PM
Good morning,
Do you have any external leaks? Is there any puddles on the ground?
If there is, you need to have the leaks identified and repaired.
https://www.2carpros.com/articles/engine-is-leaking-oil
If there are no leaks, then most likely you are burning the oil in the cylinders from worn piston rings.
https://www.2carpros.com/articles/replace-engine-piston-rings
Apr 28, 2020 at 10:05 PM
  • 55,710 POSTS
Do you have blue smoke coming from the exhaust? You may have a broken piston ring This guide can help confirm.
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Please let us know what you find.
Apr 29, 2020 at 3:42 AM
