Hard to pinpoint exactly, no common cause that I know of. A couple possibilities include crank sensors, and possibly a loss of source voltage from the ignition switch. First I would check it for codes, and also check codes in freeze frame. As far as I know, freeze frame info is only available with a factory scan tool, but I may be incorrect.
Jan 20, 2010 at 2:40 PM
