2001 Cadillac Seville Excess oil burning
2001 CADILLAC SEVILLE
150,000 MILES • V8 • 2WD • AUTOMATIC
HESHIVER
I change my oil on a regular basis, however I find myself adding at less 3 qts between changes. I dont see a oil leak but smell oil burning. What could it be?
Jan 22, 2008 at 4:51 AM
BUZZSAW
  • 1,198 POSTS
[quote:2c43f4db18="heshiver"]Engine problem
2001 Cadillac Seville V8 Two Wheel Drive Automatic 150000 miles
I change my oil on a regular basis, however I find myself adding at less 3 qts between changes. I dont see a oil leak but smell oil burning. What could it be?[/quote:2c43f4db18]
you need to take it to the dealer and have them do a cleaning of the rings (piston), the oil ring gets stuck and you burn oil. They do this with chemicals, and you may have to do it a couple times. It works, I have done it numberous times.
Jan 22, 2008 at 8:13 AM
