Oil power out top of oil pan when engine running?
1999 TOYOTA CAMRY
175,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PKCOM81
Oil Pump gear that time belt spins broke meaning it was spinning freely without pumping oil.
Noticed this when car pulled out of garage to go to store so quickly put it back in garage, only moved car again to put it in position to change the oil pump.
The oil pump then changed but afterward when the engine started oil pouring out of top of oil pan.
Replaced old oil pan gasket with RTV, let dry 24 hours, started engine - same problem.
Then I tried a new oil pan gasket instead of RTV but the same problem.
Then I tried with a new oil pan and new oil pan gasket - same problem.
Any thoughts on what could be the root cause?
May 18, 2023 at 10:38 PM
  • 55,433 POSTS
We need to see where the oil is leaking from, it could be the oil pump itself or the oil pressure sender or possibly the oil filter.
This guide can help:
https://www.2carpros.com/articles/engine-is-leaking-oil
Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 19, 2023 at 5:26 AM
