Oil on crankshaft sensor
115,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
TIMOTHY FAULKNER
I changed my crankshaft sensor and it was covered in oil but the starting motor seems to spin.
Dec 10, 2017 at 9:15 PM
  • 31,937 POSTS
I do not have any information on this motor, you can have a sensor that reads off the drive plate and will be dry, or one that reads off the crank shaft and this will be wet. what exactly is the problem and why did you remove the sensor?
Dec 11, 2017 at 6:10 PM
