Oil leakage
203,000 MILES
MALAN42CARPROS
It appears that the valve covers are failing and leaking oil onto the engine and exhaust.....How difficult of a job would it be to replace the gaskets myself....? I consider myself medium to upper on a skill level for car maintenance and repairs.Just looking at the project, it doesn't appear to be difficult but there are always the unknown details that will blow my plan up.....
Thank you,
Mark
May 8, 2013 at 2:08 AM
WRENCHTECH
  • 20,760 POSTS
What's the 8th digit of the VIN#?
May 8, 2013 at 2:33 AM
MALAN42CARPROS
The engine is a 24 valve DOHC V6
8th digit= S
May 8, 2013 at 4:03 AM
WRENCHTECH
  • 20,760 POSTS
It's certainly not a quick and easy job. The intake has to be removed to access the rear cover. The flat rate time for both sides is almost 3 hours so probably 5 hours to someone inexperienced.
May 8, 2013 at 6:16 AM
