1994 Mercury Sable major oil leak
160,000 MILES • 6 CYL • FWD • AUTOMATIC
MLADYTOY
Since Saturday (today is Wednesday), my car has gone through 1 1/2 gallons of oil! I put 3 quarts in on Saturday and never really went anywhere very far.
Today I drove about 25 miles, and the oil light went on. I pulled in a gas station and checked the oil to find that the dipstick came out almost clean! I added two quarts, and the light went out. I drove 12 miles back and everything was fine. The car sat for about 4 hours, and then I drove 5 miles and the light went on again, same story.
What is the cause and how much should it cost to repair?
Thank you!
Jun 16, 2009 at 7:21 PM
  • 31,937 POSTS
Hi there,
How much of this is external leaking? if it is burning the this amount you must be driving in a permanent blue haze, for that much oil to be burnt it could only be pistons & rings, and external leakage of that magnitude could be a torn rear main seal, cracked pressure sender may be, how much is drooping on the road?
Mark (mhpautos)
Jun 16, 2009 at 10:34 PM
