Oil gauge fluctuating?
250,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
NELZIE
When the truck is started on a cold day the oil gauge will be right in the middle but once the truck heats up slowly drops and I'm stopped at a red-light the gauge goes all the way down but when in park the gauge stays steady .
Jan 17, 2023 at 4:11 AM
  • 55,721 POSTS
This can happen on older engines because the bearing clearances are starting to get out of spec. Also, if the oil pump is worn out or the pressure regulating spring is broken it can happen as well. You might want to try changing the oil to a heavier weight such as 10/40 or 20/50, roll a new filter on as well.
Jan 17, 2023 at 8:48 AM
HAVAS BORES
As a Chevrolet long time shop foreman, I completely agree with Short Flame. Engine oil pressure changes with engine RPM. Simple as that. I can never understand why people have a problem understanding this. An engine oil pump RPM is directly connected to engine RPM.
Jan 17, 2023 at 3:14 PM
NELZIE
Would Lucas oil thickener for high mileage motors work?
Jan 17, 2023 at 3:18 PM
  • 55,721 POSTS
Yes it will, I have used it many times.
Jan 18, 2023 at 2:26 AM
