1998 Dodge Dakota Gauges
JMACIALEK
  • 1998 DODGE DAKOTA
  • V8
  • 4WD
  • MANUAL
  • 75,000 MILES
'98 Dodge Dakota truck that runs good and seems fine. When coming to a stop occasionally, the oil pressure gauge drops to zero and the check gauges light comes on. After several seconds the gauge recovers and the light goes off. There are no other noises or signs of no oil pressure. The problem occurs only when stopping regardless of how fast and not every time.
Thanks
Thursday, February 4th, 2010 AT 12:02 PM
  • 109,700 POSTS
If you are not hearing a knocking or ticking from the engine, chances are the oil sending unit is bad. Try replacing it.
Let me know if it takes care of the problem.
Friday, February 5th, 2010 AT 7:51 AM
