1992 Dodge Dakota oil pressure guage original accessory
78,201 MILES • 6 CYL • 2WD • AUTOMATIC
92MATOR
My oil pressure guage sems to register mostly in the middle. When I start it up on a cold day, warm day, engine cold or warmed up. It stays in the middle at idle or moving. What should I do to check what is going on with this.
May 30, 2009 at 8:17 AM
  • 110,244 POSTS
That sounds normal; however, if you are concerned, I would start by replacing the oil sending unit. it's above the oil filter, not an expensive part, and easy to replace.
Let me know if that helps.
Jun 1, 2009 at 4:45 AM
