Odometer stays on
235,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
MOLINA42
I just changed my heater core and the o my issue I am having now is that my miles light and my PRND light stays in 24/7 and I do not know why.
Nov 11, 2018 at 9:06 AM
  • 110,248 POSTS
Since you were working under the dash, it sounds like you shorted a hot wire to the mentioned components. Check for wiring issues where you were working. Make sure none of the wires were accidentally pinched between components you removed and replaced. Also, make sure there are no wires with the insulation scraped off.
When looking, the transmission range sensor is powered by a brown wire with a light green tracer on it. Try to locate that and check for interference from prior work.
Let me know what you find.
Nov 12, 2018 at 9:47 AM
MOLINA42
Okay great, thanks for helping me.
Nov 12, 2018 at 10:31 AM
  • 110,248 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
Nov 12, 2018 at 11:51 AM
