Car is not accelerating right
90,000 MILES
CHELSEA_BEST
Hello, this morning i turned my car on and everything was fine and as I get down the street my car is not accelerating right, kind of felt like I was in neutral . So I took it to the shop and they found a code P1759 which is the front brake solenoid valve function. They said it’s basically my car puts its self into third gear . I’ve never had any other problems with my car . I only have 90,000 miles on my car if that helps . Not sure what else to do .
May 17, 2019 at 12:22 PM
  • 55,740 POSTS
I would start by servicing the throttle body because it sounds like the car is going into limp mode. here is a guide to help you:
https://www.2carpros.com/articles/reduced-power-limp-mode
May 18, 2019 at 4:07 AM
