When I first start the car say when I first get up in the morning it will start up and slowly shut off unless I give it some gas up to 2500 rpm's for a few seconds then it is fine unless I do not crank it for along spat. it is reading a p0400 EGR valve and a idle air valve, also I have been having idle issue. I adjusted the cable and reset the IAC.
Apr 13, 2018 at 2:51 AM
