My car cranks And won't start.
160,000 MILES • 6 CYL • AUTOMATIC
AYANE21
I change the knock sensor the camshaft,crank sensor , starter , fuel filter, air filter the alternator, coils everything and still won't start but it cranks please help me
Jun 21, 2015 at 12:34 PM
ED-WEEZY21
  • 248 POSTS
Have you had the fuel pump inspected? I would test for fuel pressure. You may have a fuel problem. If its not a fuel problem, I would perform a compression test and see where your readings are. They should all be around the same compression.
Jun 25, 2015 at 10:02 AM
