Not starting
STACI2527
  • 2002 FORD EXPLORER
  • 4.0L
  • 6 CYL
  • 4WD
  • 184,000 MILES
It's turning over but its not getting gas and the fuel pump is coming on
Monday, December 21st, 2015 AT 1:32 PM
JDL
  • 16,098 POSTS
With engine cranking, I want to check spark at the spark plugs, where applicable. Use a gage and check proper fuel pressure, engine cranking and check fuel injector pulse.
If you missing all three, check for an rpm signal, should come from crank sensor. Don't replace anything unless your testing points in that direction.
Also, check your security/theft system.
The fuel pressure you saw, might have come from the initial prime, that doesn't need an rpm signal.
Tuesday, December 29th, 2020 AT 12:13 PM
