2002 Ford Explorer
ASHLEYOWASSO
  • 2002 FORD EXPLORER
  • 6 CYL
  • 118,000 MILES
My car will randomly not start. The terminals were corroded and I cleaned them and the wiring. The battery is brand new. When the car doesn't want to start I jump it (and it starts every time I have done this). I also noticed that if I throw it into neutral that it will start 100% of the time. My engine light is on and it pertains to my EGR (valve or sensor: I don't know which one). What could be my problem?
Thursday, March 19th, 2009 AT 6:11 PM
BLACKOP555
  • 10,371 POSTS
When it wont start, what does it do? Click? Nothign at all? Starter engages and cranks engine it just dont turn over?
Do all warning lights come on like normal and fuel pump when vehicle wont start?
Thursday, March 19th, 2009 AT 8:30 PM
ASHLEYOWASSO
All the lights are normal, and fine. It cranks and clicks but it just doesn't turn over. And the fuel pump works when the vehicle won't start.
I personally think its my neutral safety switch.
Friday, March 20th, 2009 AT 6:59 PM
BLACKOP555
  • 10,371 POSTS
If its the neutral safety switch it wouldnt crank at all. When it wont start check the fuel pressure and teh presence of spark. Let me know what you find.
Friday, March 20th, 2009 AT 9:12 PM
HELPING YOU
  • 100 POSTS
You said it "cranks but won't turn over" - that's two terms for same thing to a mechanic. Ya, nuetral safety switch sounds good - don't know why jumping would help, though. This symptom sometimes occurs with poor connections, check at block and starter too not just at battery, a tight connection's not always good - a "voltage drop" test will show problem - very easy to do if you understand it. Either do some testing or replace it and go from there(or just put it in nuetral) The CEL is likely the DPFEGR sensor - there's a TSB - if it's "tube mounted" it just sticks on top of the two rubber tubes - simple to get at/change.
Friday, March 20th, 2009 AT 9:30 PM
