Not starting
2000 PLYMOUTH BREEZE
15,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
ANGELACHITTY
  • 7 POSTS
Hit a pot hole damaged the oil pan, oil got low enough the shut engine off. Changed oil and filter, but not wanting to start, when go to turn over it acts like it wants to but not getting fire, went thru all steps but just won't turn over
Sep 7, 2016 at 3:47 AM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online.
Sep 7, 2016 at 5:04 AM
ANGELACHITTY
  • 7 POSTS
Thank you for your reply, sorry not get right back with you, doing this myself, single mom and working . I will try this and let you know the outcome
Sep 8, 2016 at 2:24 AM
  • 55,423 POSTS
It sounds like the engine maybe locked up, does the engine turn over normally?
Please let us know what you find so it will help others.
Best, Ken
Sep 14, 2016 at 11:34 AM
ANGELACHITTY
  • 7 POSTS
Normaly it does, can be turned by hand, it's not locked up, like I said, it wants to but not , and it does not have a security light that comes on. Would it be possibly be that the brain needs a reboot.
Sep 14, 2016 at 2:15 PM
ANGELACHITTY
  • 7 POSTS
The timming belt is good, so that eliminates that, changed crank shaft sensor , the oil sensor cut the engine off, we even tried changing the coil pak, when you go to crank the car it seems as tho it wants to turn over but doesn't. Like there is no compression. It not getting the fire it needs to start.
Sep 14, 2016 at 2:22 PM
HMAC300
  • 48,601 POSTS
check the compression on this. if timing is off on cam it will have low compression
Sep 14, 2016 at 10:42 PM
  • 55,423 POSTS
Here is a guide that will help you
Sep 15, 2016 at 5:21 AM
ANGELACHITTY
  • 7 POSTS
Well it turns out that, from a friend's mechanic, that not only low compression but oil pressure is nil, also. Timming and components good, cam shaft and I'm guessing the housing for cam messed up got metal shavings in there. He said it would cost me 21st to much to fix, that I'd be better off getting another vehicle. I appreciate your help and keeping you in address book, lol. You guys are wonderful. Thank you again.
Sep 18, 2016 at 12:03 PM
ANGELACHITTY
  • 7 POSTS
Well it turns out that, from a friend's mechanic, that not only low compression but oil pressure is nil, also. Timming and components good, cam shaft and I'm guessing the housing for cam messed up got metal shavings in there. He said it would cost me to much to fix, that I'd be better off getting another vehicle. I appreciate your help and keeping you in address book, lol. You guys are wonderful. Thank you again.
Sep 18, 2016 at 12:05 PM
  • 55,423 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ke
Sep 19, 2016 at 2:14 AM
