Not running
1 MILES • 4.9L • 6 CYL • 2WD • MANUAL
KARL_
I had done an engine swap and went from a 240 to 300, but I put the 240 ignition parts and carburetor on the 300. Now the engine will only run on full throttle and full choke. Unsure what to do as I am not great with how carburetors fully work. Thanks
May 24, 2018 at 3:30 PM
Good morning.
When you have to run on full choke, that is an indication of carburetor issue.
You most likely will need to either have that one rebuilt or get a replacement carburetor. Not enough fuel is getting into the engine from the carburetor. That is why you have to full choke the carburetor.
May 24, 2018 at 9:51 PM
KARL_
Thank you very much I will look into that.
May 25, 2018 at 8:24 AM
You are welcome.
Found a carburetor for you. Not expensive at all.
https://www.rockauto.com/en/catalog/ford,1966,f-100,4.9l+300cid+l6,1492966,fuel+&+air,carburetor,5904
May 25, 2018 at 8:26 AM
