won't start
999,999 MILES
RHONDA TUGGLE
It will turn over but won't start. I have touched the coil wire to the distributor but there is not fire. What could be the cause of this problem?
May 2, 2013 at 12:19 AM
HMAC300
  • 48,601 POSTS
scan for codes first and check fuel pressure check fuses underhood. check pickup coil in dist for ohms , shold be around600 ohm range I think. check fusible links running off of starter relay by battery
May 2, 2013 at 1:41 AM
