Not getting spark from coil?
130,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
NELL MAY
I overheated my car and it shut itself down. Now it will not start it turns over but is not getting any spark from the coil. What to do?
Feb 9, 2023 at 8:00 AM
NELL MAY
I did check all the fuses.
Feb 9, 2023 at 8:05 AM
CARADIODOC
  • 34,414 POSTS
The first step is to read and record any diagnostic fault codes. Chrysler made doing that yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds, without cranking the engine. Leave it in "run", then watch the code numbers appear in the odometer display. You can go here:
https://www.2carpros.com/trouble_codes/obd2/p1400
to see the definitions, or I can interpret them for you.
After that we will need to see if the automatic shutdown, (ASD) relay is turning on. The best tool for that is a simple test light. If you've never used one, check out this article:
You can find a perfectly fine test light at Harbor Freight Tools, Walmart, or any hardware store or auto parts store. We'll be testing on the wire that is the same color at every injector and ignition coil. I'll find the diagram in case we need it.
Let me know what you find with those fault codes.
Feb 9, 2023 at 11:28 AM
