Not charging
100,000 MILES • 2.2L • 6 CYL • 2WD • AUTOMATIC
JEFF HERMAN
  • 486 POSTS
I took my 1964 Dart 270 out the other day. I noticed the battery gauge was pinned to full charge. This was not normal. I just thought it was bringing the battery up to full charge . After a while the gauge dropped but still not to it's normal position. It was at 3/4, usually just to the right of center. Later that night the gauge went to left of center and when I checked with a multi-meter it was not charging. I checked all the connections and the alternator leads for continuity and all were okay. I cleaned the points in the regulator too. It is still not charging and I don't want to jump to replacing anything without doing some troubleshooting first. What do you think has happened? Are there some more steps I can take to further diagnose the issue? Thank you for your assistance as always.
Sep 16, 2019 at 8:58 AM
Good evening,
I would replace the regulator. That is what controls the output of the alternator.
Sep 16, 2019 at 9:04 AM
JEFF HERMAN
  • 486 POSTS
Should I get the alternator bench tested?
Sep 16, 2019 at 9:06 AM
You could but if it is overcharging, chances are it is good.
Use a voltmeter and test the voltage at the battery with the engine running.
It should be 14 to 14.5 volts.
Sep 16, 2019 at 9:10 AM
JEFF HERMAN
  • 486 POSTS
It's not charging at all.
Sep 16, 2019 at 9:34 AM
Okay, then have the alternator checked. I would replace both the alternator and regulator.
Sep 16, 2019 at 9:43 AM
JEFF HERMAN
  • 486 POSTS
Okay, thanks. I'll let you know what happens.
Sep 16, 2019 at 9:48 AM
You are welcome.
Always glad to help.
Sep 16, 2019 at 9:51 AM
