1968 Dodge Dart Charging system
1968 DODGE DART
196,000 MILES • V8 • 2WD • AUTOMATIC
TRAFO
The battery does not charge, it is about 4 years old. The reading is 12.28 V. The voltage regulator used to have bad terminal contact, but after each cleaning it used to work, until now. The voltage on the alternator terminals with the engine running (started with quick start battery) is fluctuating between about 4 to 7 V, depending on throttle speed.
The car runs fine once started.
Which component is faulty? How can I measure to be sure?
Nov 24, 2008 at 5:50 AM
Have both the battery and alternator load tested-those voltages are way too low-when engine is running you should have 13.5-15.5volts if the charging system is working properly.
Nov 24, 2008 at 6:55 AM
