Normal Accord STFT Value
180,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
NICKQP
Hi, my car has seen a noticeable drop in MPG rating so I hooked up my scan tool to track my STFT 1 percentage.
The range from highest to lowest was from +7% to -18%.
Is this normal for my car?
Also, my o2 sensor had a consistent voltage of8% so I tried to induce a lean response by pulling the PCV valve, and no change.
Someone told me that Accords do not have o2 sensors but have AF sensors instead and you cannot test it using voltages. Also, pulling a PCV valve on a MAP based vehicle will not cause the car to run lean. Is this true?
Thank you!
Mar 23, 2016 at 11:43 AM
  • 55,464 POSTS
Its sounds like the O2 sensor is non responsive I would start there, here is an article to how to replace it, not the same car but you get the idea
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Mar 25, 2016 at 4:29 PM
